Multifunction DAQ
Can I use a PCI-6251 AO channel without reference to AO GND?
(3,910 Views)
Hi jacsjj,
Without referencing to ground, there is no way of knowing the voltage of your signal because voltage is just a potential difference between two points.  The analog output is outputting a voltage that is a certain amount above or below the ground reference.  For information about wiring your DAQ card, please refer to the Developer Zone, Field Wiring and Noise Considerations
Jim Schwartz
(3,896 Views)
Thanks for the fast response.  I was hoping there would be a way to float the output without referencing ground (like a floating power supply).  The user manual mentions the following.  Would this allow me to output the signal as a differential output or am I misunderstanding the concept?
You can connect an external signal to APFI <0..1> to provide the AO
reference. The AO reference can be a positive or negative voltage. If AO
reference is a negative voltage, the polarity of the AO o
utput is inverted.
The valid ranges of APFI <0..1> are listed in the device specifications.
(3,890 Views)
You could use a module such as these to provide full isolation, there are many manufacturers. These have a response up to 10KHz.
http://www.dataforth.com/model.view.aspx?modelid=91
-AK2DM
(3,884 Views)
Thanks.
(3,877 Views)
Hi jacsjj,
The APFI line can be used as a reference to get better resolution on your AO signal.  If you provide an external reference to the APFI line, your range will change from +/-10V to +/-AO Reference.  You can find more information about this on pg. 86 of the M Series User Manual .  I don't think this is exactly what you want to have happen.  The 6251 cannot use an external reference like in a floating power supply.  You will either need an isolation module or an isolated DAQ card.
Jim Schwartz
(3,875 Views)
Thank you.  This clarifies it for me.  I appreciate your help.
jacsjj
(3,860 Views)
