Multifunction DAQ
Can I run Bitlocker with a TPM 2.0 Chip Real-Time?
I want to Bitlocker a cRIO's hard drive using the onboard TPM 2.0 chip provided in a PXIe.  I need this device to collect information and run as real-time target using the WES OS provided.  Which application does Windows Embedded Standard (WES) Operating System (OS) use for running real-time targets?  Can this be done to where when the controller is deployed, the real-time target receives information within the WES OS?
I see that Labview cRIO offers the WES and Ni LinuxRT embedded OS'.  I am confused as to whether the LinuxRT only runs real-time and the WES only runs as run-time or can the WES run as Real-time with bitlocker and provided TPM?
Can someone please explain to me better?
Thank you! 🙂
Message 1 of 1
(1,260 Views)
