Multifunction DAQ
Can I reduce the amount of delay in executing a digital output written to 6008 DAQ?
I have a 1.7 second delay in the output of a digital signal from a CD&sim loop that is destroying a dynamic model.  I have stripped everything down to the following vi to isolate where the delay is coming from.  Is this a problem with the arrays or the hardware?
This is with a NI 6008 usb DAQ using labview 2009.  I attached the simplified vi below.  Any ideas on how to make this faster?  Like less than .5 seconds?
(2,808 Views)
How exactly are you benchmarking your code? I know that you have isolated it to this particular VI, but have you broken it up further to determine where most of the time is spent? I would also recommend against using the DAQ Assistants in applications such at this because they introduce additional overhead in time sensitive applications. Here, you would want to use the DAQmx lower level API.
-Zach
(2,780 Views)
