Multifunction DAQ
Can I compile DAQmx7.5 programs with DevC++?
we are beginning to acquire measurements with NI-USB6009 DAQ and we installed NIDAQmx7.5 libraries to exploit its advanced features. But when we compile with Dev C++ the example files we have  linker errors such as    " [Linker error] undefined reference to `DAQmxCreateTask@8' ", for every DAQmx function we call.
For the NIDAQmxBase these errors didn't occur. How can we solve this problem using Dev C++?
Thanks for your help,
Marco
Message 1 of 10
(5,448 Views)
Make sure you are linking with NIDAQmx.lib. You will find it in
Program Files\National Instruments\DAQmx ANSI C Dev\lib\msvc\
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
Message 2 of 10
(5,433 Views)
Yes I compile with NIDAQmx.lib, and import libraries and include files. I think the problem is with the Dev C++ compiler itself.
Message Edited by superfrenkie on 08-30-2005 11:58 AM
Message 3 of 10
(5,427 Views)
Oh. I'm using VC++.net with success. I'm building a DLL using standard C++. Are you using anything special like managed code? (I'm quickly getting out of my depth here)
The "@8" on the end looks like a mangled name of some sort. You may need to do something to turn off the mangling.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
Message 4 of 10
(5,419 Views)
the true point of the issue is that DevC++ is probably not completely supported. This is basically why you are getting linking errors to 'DAQmxCreateTask@8' and others probably. The final @8 reports the size of the parameters the function is expecting or something similar.
Anyways, I suggest you take a look at JoeSavage's approach on this web page .
He basically posted a Wrapper DAQmx C code that can be included in your C code and resolve the names the linker is missing.
AlessioD
Message 5 of 10
(5,411 Views)
I tried to compile NIDAQmx.c inside my project as the post's author suggests but the compiler returns this error '' invalid conversion from `void*' to `int32 (*)(const char*, TaskHandle*)'  '' for this line of code '' if (!(DAQmxLoadTask_Ptr = (void*) GetProcAddress(DLLHandle, "DAQmxLoadTask")))  ''. This is repeated for a lot of similar instances and I don't know how to fix it. Perhaps the whole procedure is incorrect, should I compile NIDAQmx.c in another directory?
Thanks a lot, Marco.
Message 6 of 10
(5,410 Views)
we tried to overcome the problem using the Visual C++ command line compiler. The compiling and linking are ok (for example we tried with the ContAcq-IntClk.cpp file  from NI) but  if we run the program we have the following error
DAQmx Error: Device identifier is invalid.
Device Specified: Dev1
Task Name: _unnamedTask<0>
Status Code: -200220
End of program, press Enter key to quit
What could be the cause in your opinion? OurDAQ is the USB6009. Thanks a lot,
Marco
Message 7 of 10
(5,398 Views)
the USB-6008 device needs to be recognized by NI_DAQ 7.5 under MAX. You need to follow the indications reported on this KnwoledgeBase  in order for the Device to be assigned a correct identifier. AlessioD
Message 8 of 10
(5,395 Views)
Great!
thanks for your suggest, everything seems to work fine, the problem was to switch the device between NIDAQmxBase and NIDAQmx. Now we can choose to work with DevC++ or command-line VisualC++...
Marco.
Message 9 of 10
(5,392 Views)
If you're compiling this as C++, you can't automatically convert a void * to other types. I'm not sure about function pointers and C; I thought with standard C this would be OK. You will have to cast the return value of GetProcAddress to the actual function pointer type, like this:
typedef int32 (* LoadTaskFuncP)(const char*, TaskHandle*);
DAQmxLoadTask_Ptr = (LoadTaskFuncP)(GetProcAddress...
or, using more modern C++
DAQmxLoadTask_Ptr = reinterpret_cast(GetProcAddress...
The typedef is just to make it more readable. I haven't compiled this, so take warning...
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
Message 10 of 10
(5,381 Views)
