Multifunction DAQ
CVI6 and DAQmx
Some years ago I have writtenan application that acquire 11 analog signals at every ten seconds and display it and store etc.. (simple datalogging)
Unfortunately this application has been written in CVI 6 using easyio function nidaqAISingleScanOp ("daq::1!(0:10)", 0.0, 0.0, adcReads);
Actually we need to change the analog input board using a new one (pci-6220) that support NIDAQmx and NOT old DAQ functionality required by easyio CVI library.
Does it exist a "wrapper"for CVI6/NiDAQmx or I have to rebuild (and rewrite) the application using CVI7.1 ?
I have noticed that it exist for Labview:  may I use it wit some "tricks"?
Thanks in advance
Raffaele
(3,273 Views)
Hi, unluckily it does not exist a DAQ migration tool for CVI, but above all you need CVI7.x to have full DaqMX support, even if you could try to use standard C support in CVI6.x.
Don't be scared about new daqMX driver, it is very easy to use even without Daq Assistant (wizard that creates code for you available in CVI7.x).
Take a look at the attached file for an example of a finite acquisition that should work as your old ScanOp.
Write back if you need more help.
Ciao. Nicola.
Message Edited by Nick_ on 09-07-2005 11:39 AM
(3,261 Views)
HI  NICK:
Can you provide me example for simultaneous data acquisition using several (may be 5 or 6) Analog Input channels.
I am beginner with Lab Windows .  I haveCVI 7.x and   NiDAQmx   PCI-6220 card.
Please provide me with some more examples.
Anyways Thanks for your previous example.
Regards
Dinesh
(3,227 Views)
Hi, the sample attached to previous message works for more than one channel too.
Just input a Physical channel as "Dev1/ai0:3" and you'll acquire first four board's channel, or input "Dev1/ai0,Dev1/ai2" and you'll acquire from first and third channels.
You'll find more examples in your PC, browse to C:\Program Files\National Instruments\CVI71\samples\DAQmx  and you'll find Daqmx ones.
Hope this Helps.
regards
NicolaC
(3,216 Views)
