Multifunction DAQ
CB-68LP
Hi:
Can CB-68LP measure TTL current?
Can PCI-6250 also measure TTL current?
Or basically they both are the same because they have the same pinout?
I want to make sure and your direct answer. Thanks!
I am in a urgent. Many thanks if you can reply to me promply.
(3,075 Views)
Another Deja Vu momentSmiley Wink
The CB-68LP does not measure anything. It is a terminal block.
The PCI-6250 measures voltage. You can determine current by taking a voltage measurement across a known resistor. I don't know how to make it more direct than that and it's the same answer you've gotten several times already.
What do you mean by TTL current? TTL refers to a type of digital circuit. Current is current whether it is used by a TTL device or analog device.
(3,076 Views)
