Multifunction DAQ
CB 68LP
I've been asked to automate a high pressure dual piston pump. This pump, at one point, had a computer running LV attached. There is a CB 68LP connector board and ribbon cable still attached. There is no wiring diagram. There are several digital outputs and possibly several analog inputs. Off the top of someones head, which NI PCI card might have been used with this connector board? I'm assuming a PCI board since the pump has been sitting around for many years, minus the computer.
Thanks for any help,
Bob Horn
(3,214 Views)
Hi Bob,
It is tough to say --since the 68LP can connect to any 68-pin data acquisition device, any of our Multifunction DAQ's could be a possiblity.
You could perhaps narrow it down based on the number of Digital and/or Analog lines by searching through http://www.ni.com/dataacquisition/multifunction/
Any other clues you could provide?
Best,
Ryan C.
(3,203 Views)
Thanks Ryan,
There are at least four digital outputs, maybe six digital inputs, although some of those may be hardwired to the motor controller,and four analog inputs. I don't have access to the unit right now so I was just being lazy. I'll take a look at the site you suggested.
Bob
(3,201 Views)
