Multifunction DAQ
C source code example
I've just installed the current release of the NI-DAQmx libraries.  The installation/setup was configured to install C source code examples i I am not able to find the C source code examples but I am not able to find them.   I've done this twice and still am not able to find the example source code.  Can anyone explain what I need to do to install/find the C source code examples?
Ian
(4,379 Views)
Hello Ian,
the installation folder for the ANSI C examples depends on your system and NI-DAQ version.
You can check:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\
or
C:\Program Files\National Instruments\NI-DAQ\
Hope this helps.
LDP
(4,363 Views)
I've already checked for both directories but they do not exist.   The only directory created was 'C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0'.   It is my impression that the current NI-DAQmx installation program is simply not installing the C source code examples.
Ian
(4,361 Views)
From I assume the "C:\Users\Public" directory you mentioned, I can assume that you're running on Vista?
In that case, the ANSI C examples will be installed into the directory you specified, exactly here: C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
If they are not being installed, the ANSI C option in the installer is likely not checked off.
If you are having a problem with the installer, I would try removing NI-DAQmx and re-installing it again.
Hopefully this helps.
LDP
(4,356 Views)
Yes, I am working with Vista.
I've installed several different versions of the NI-DAQ library over the past few years and have a pretty good idea of what to expect.   In this case, I am not able to find any C source code.   I need the code because NI appears to have changed the way one of their functions operates and this would be confirmed in the source code.   I will try re-installing everything for a third time and if this does not work, will post a bug report.
Ian
(4,345 Views)
The problem appears to have been caused by the setup program itself.  I orginally downloaded the current release last month.   Uninstalling and re-installing did not copy the C source code to the hard drive.   Today, I downloaded the installation program a second time and re-installed the NI drivers using this download.    The C source code has now been copied to my hard drive.
Ian
(4,336 Views)
