Multifunction DAQ
Bug report
Software:     NI-MAX v 14.5 or NI-MAX v15.0
If the channel names in a task exceed 500 characters, the import function will display a message stating that "A property is missing - 'SampQuant.SampMode'" and fails the import of the configuration.
(3,810 Views)
There is most likely a limit on the length of channel names tasks in MAX. I haven't been able to find any current documentation stating the limit as 500 characters, but have found an older tutorial here that says virtual channel names should not exceed 256 characters. If you are trying to use multiple physical channels, follow the syntax guide here to try and cut down on the length of the channel names.
Eden K
(3,775 Views)
