Multifunction DAQ
Bigger period of sampled with LabWindows
Dear all:
I am programming a DAQcard 700 with Labwindows CVI and I am using the traditional NIDAQ. On he one hand I don't unaderstand very well the diffrerence between Scan rate and Sample rate.  On the other hand, I am using the High level function Lab_ISCAN_Op (1, 2, 1, piBuffer, 1000, 1000.0, 0.0, soBuffer); and I have the limitations of a buffer of 65535 samples, however I woul need a time of sampling much bigger in a continuous sampling, for instance with a frecuency of sample of 10000 Hz and  during several minutes. ¿Could you help me in this matter?
Thank you very much.
(2,771 Views)
Hi Fernando
Most of the terms used in Data acquisition are explained on this link
http://digital.ni.com/public.nsf/allkb/DBE7AC32661BCF9B86256AC000682154
For high speed, long acquisition you should use continous acquisition. This link explains how it works
http://zone.ni.com/devzone/conceptd.nsf/webmain/F2DDCBAD754C687C86256802007B8514?OpenDocument+
You could find examples about how to do it in your c:\Archivos de Programa\National Instruments\CVI80\Samples\DAQ folder
Hope it helps
Javier Gutiérrez
NI Application Engineering
(2,746 Views)
