Multifunction DAQ
Automatically quantifying varying time intervals
I have an incoming signal that has been extrinsically modulated to have time periods with zero signal amplitude and also maximum signal amplitude (ON/OFF), which are equal and variable. I want to quantify such intervals to be used for further computation. How can I do this?
(3,474 Views)
Hi Danilson,
Is the signal a square wave and you want to meausure pulse width and/or duty cycle?
Do you have an example of what it might look like?
Tony
(3,460 Views)
Hi Tony,
 I attached a picture of the externally modulated signal obtained as I described earlier. I would like to determine the pulse width (duration where the amplitude of the envelope signal is not at minimum) of this received signal, not the pulse width nor duty cycle of the actual data contained in the received signal.
I have a control to vary these pulse widths and would also like concurrently quantify any change made.
Hope to hear from you.
Many thanks!
Danilson
(3,455 Views)
Hi Danilson,
Have a look at the Peak Detector VI.  It gives the locations of all the peaks or valleys in the signal.  There a seven pulses in each major pulse, so you would know where to split out the data.
If you can post a same of the waveform data, I could have a further look.
Tony
(3,411 Views)
