Multifunction DAQ
Automatically Retriggered AI
I have an application where I need to have N data points aquired at rate S every time a digital trigger is detected.
For example, in one application the trigger signal will occur @ roughly 100Hz.  In this case we want 10 samples at 10Khz.
Is there a way to set this up so the acquisition gets ready to re-acquire after each acqusition, without software interaction?
(3,087 Views)
Here in this knowledgeBase document you can find your answer.
http://digital.ni.com/public.nsf/allkb/82DAECADE90CC56F8625659200675B2A
(3,070 Views)
