Multifunction DAQ
Are there USB-6008 drivers for a stand alone application
I have an application that we send out on a touch panel PC. It is a stand alone application so Labview is not installed and only the runtime engine and appropriate drivers. I am using a NI-6008 for some digitial and analog input for the program. Are there seperate drivers I can install for this device? Right now I am having to install NI MAX9.0.2 so there are drivers for it and it is a rather long and tedious process.
The application was developed and compiled under Labview 8.6. I was also lazy and did not make a full installer, so I install the runtime engine and serial drivers seperately. Since we set these up all here before they ship out, I have never bothered to go back and make a full installer. It isnt bad to do it this way until I get to having to install MAX.
Thank you!
Garrett Herning
(3,604 Views)
DAQmx is the driver you need.
(3,603 Views)
Have you seen the runtime versions of DAQmx?
(3,594 Views)
