Multifunction DAQ
Application builder
Hi:
I am trying to find application builder. See the link below
http://zone.ni.com/devzone/conceptd.nsf/webmain/5ADBC06AC32E508A8625706E0062EBD1
I can not find buld application dialog box and project explorer dialog box. See attached document.
Could you please tell me where I can find it
I am in a very urgent. I appreicate your quick reponse. Thanks!
(3,879 Views)
(3,874 Views)
If you do not see any Build Application options in your LabView environment, then you have to purchase the Application Builder separately. It does not come in the Base version of LV. What version and package level is your LabView? Version can be found under Help.
Here is a link for App Builder add on:
https://www.ni.com/en-us/shop/product/labview-application-builder-module.html
(3,875 Views)
Hi AnalogKid:
The version is 7.1 and I tried to use the Application Builder. It worked when I uncheck the Create Installer. I don’t know why I got the message that test.vi could not be found. Attached was the my document to show how I creat. Did I do anything wrong?
Another document shows what program I have installed in my computer. Do you think I have the driver installed already?
John
(3,832 Views)
You've got no attachments that show what you did, no attachments about any message, and no attachments that shows what you have installed. What worked when you you unchecked Create Installer? If something worked, what then is the problem? What is test.vi? Is that the name of the source file you are trying to create an application from? The .doc you attached above is from NI's site and is of no help - especially since half of it refers to LabVIEW 8.
(3,821 Views)
