Multifunction DAQ
Analog input errors when using multiple channels with different ranges
Has there been any progress on this issue? This is a serious bug for us and the requirement for extra channels is limiting how fast we can run the hardware.
Message 11 of 18
(2,716 Views)
Hi Chris,
We're researching long-term solutions.  There should be more information available next week.  For now, there are two workarounds, and the tradeoffs are maximum sampling rate and measurement sensitivity.  For applications where the sampling rate is more important, I'd recommend using a consistent input range across all channels.  Where there is more emphasis on sensitivity, using the extra channels is the way to go.
For your application, how many channels are used, what sampling rates are required, and how are your accuracy requirements defined?
Message 12 of 18
(2,674 Views)
Chriss, I don't know your needed uncertaincy, but to solve the issue in hardware (seems that you need to cover two ranges) : TI abd AD make nice high side current shunt amplifiers, that will bring all shunt voltages to the same (low impedance) level .
Greetings from Germany
Henrik
LV since v3.1
Message 13 of 18
(2,633 Views)
Thank you, Henrik. If we have a chance to redesign our board, the LTC6102 will work nicely.
Message 14 of 18
(2,617 Views)
Any updates on CAR #483646?
Best Regards,
John Passiak
Message 15 of 18
(2,526 Views)
I have not heard anything. For me, this has turned out to not a big problem once identified. Still, I feel sorry for the poor suckers that are dealing with this bug thinking it's something wrong with their setup.
Message 16 of 18
(2,522 Views)
Yeah, I just came across this other post and it seemed a little suspicious:
http://forums.ni.com/t5/Multifunction-DAQ/Single-DAQ-task-six-channels-RSE-and-Differential-modes-mi...
Now I'm also curious for my own sake--we use a good number of X Series cards in our own applications.
John Passiak
Message 17 of 18
(2,490 Views)
Hey John,
The CAR has been closed.  Our initial efforts to apply a software correction to the poor behavior hit a dead end when it was determined that a hardware constraint wouldn't allow for such a fix.  Our investigation of long-term solutions has made way for more auspicious corrective action, but there is no CAR tracking these changes.  Completion is still several months away.  We are in the process of updating documentation, so that any updates will be made clear with any future release of hardware or drivers.
I can assure you that this issue is limited to multi-range tasks run on 632x or 634x boards.  There is only cause for concern if you have applications where these criteria are met.  Please refer to this article for recommended workarounds.
Message 18 of 18
(2,478 Views)
