Multifunction DAQ
Analog Output parabolic scaling with Global Virtual Channels
Hello! First of all thanks for giving my message a read!
So my problem is the following:
I am trying to use a parabolic (for example) scaling for Analog Outputs using global virtual channels. Everything is fine if I want to use, say, a linear scaling, but for a parabolic scaling the interpolation is automatically done in the wrong direction, i.e. as if the function were essentially designed for analog inputs.
Do you know of any way around this problem other than programmig my own conversion routine?
Many thanks for your help!
Aline
(2,850 Views)
Are you talking about a custom scale in your global virtual channel?
If you are, you can modify the coefficient when you apply the order.
Hope that helps.
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
(2,842 Views)
