I would like to perform single-point analog output with a DAQCard 6036E on a PDA running Windows Pocket PC 2003 and have been having quite some trouble. I understand that
single-point analog output is not supported in
NI-DAQmx Base 1.0 for the DAQCard 6036E, but came accross a page on the support website that offered an example that gives the impression that it should work. The example is -- "PDA Single Point AO" as found at the following address: http://digital.ni.com/public.nsf/websearch/B6F163695654312186256E7C005C5BC5?OpenDocument
When I try to use the example, I receive the following error message: "Write cannot be performed because this version of DAQmx Write does not match the type of channels in the task. Error code: -200526". I am using LabVIEW PDA 7.1, DAQmxBase 1.0 ,and have set up a task using AO channels 0 and 1. Can I perform an analog output task using this example? Is there any special way in which the task must be configured that I may have overlooked?
Please advise on how to proceed. Any more information / suggestions would be greatly appreciated. (Also let me know if more information would be helpful.)
Aaron Woodcox
