Multifunction DAQ
Analog Output Signal
First of all, thanks for everyone who has helped me before!! you guys have been great!!
Ok, I have another problem here.... The VI that I have designed can only have AO 1-UP.vi to send out the data from my built-in function generator to the designated analog output. My goal is to send out a continuous wave-like (triangle wave)signal to my DAQ board. The signal that I'm getting now is not what I wanted... sharp increase and decrease in voltage. However, I tried the other AO.vi and they won't work. What could be the problem? COuld it be the data or the structure??
(2,556 Views)
Hello;
You can find examples showing how to accomplish that in Labview.
Just go to Search Examples->I/O Interfaces->Data Acquisition->Analog Output->Continous Analog Output.
That is the best way to start of your application.
Hope this helps.
Filipe A.
(2,556 Views)
