Multifunction DAQ
Analog Out Debug Question
I hadn't thought of that.  Relays are polarity sensitive (just learned that).
BUT
Everything is wired properly, and I had already set the test to 0-5V.  So no dice.  You had me for an instant though, then I realized I would have seen that on a DMM anyway.
Here you can see the newly rehashed block diagram.  Pay attention to the location of probe 18 and 19 (and their values).  Their "data" input is 5 and the task is configured to output on a certain AO channel.  Is there something here I am doing wrong?
Clueless,
~milq
Message 11 of 13
(1,044 Views)
I did notice one thing based on the screenshots that you posted. When you configure your tasks in MAX, they are setup for continuous output. However, in your code, you are setup to output only a single sample. I would like for you to change the analog output timing to "on demand." Try testing it in MAX first and then apply it to your program and let me know if this fixes the problem.
Hal L.
Message 12 of 13
(1,011 Views)
THANK YOU !!!!!!!!11111111one1111eleven
That fixed it, thank you so very much!!!!
~milq
Message 13 of 13
(1,008 Views)
