Multifunction DAQ
Acquisition
I am using a NI-5102 DAQ board or digitizing oscilloscope with labview 6i. I want to acquire data continuosly. I know that the fetch forever example will work, but how do I locate it in labview 6i or a similar example. Also I want to plot x and y graph continuously using the DAQ device and saving it automatically. I have designed a VI that when I run it, a page pops up asking me to indicate where i want to save my data, and give it a name. So If i find this fetch forever example how do i merge it to the VI i designed, such that they work together- one acquires and one saves and updates as data comes into the DAQ device.
Leye,
Physicst.
(3,252 Views)
Hi Leye,
Unfortunately, the 5102 is the older high speed digitizer card that does not support continuous acquisition. These older boards do not have the ability to use a reference trigger to set up read pointer for the "fetch forever vi." Using 5102 you can only read a finite number of samples and reinitiate the acquisition and fetch in the same amount of data again.
I recommend you upgrading your device to a newer generation of digitizers like the 5114 or 5122 which do support the full functionally of NI-Scope driver and continuous acquisition.
(3,227 Views)
Thanks for your response. Well if I cannot do continuous acquisition, what example in labview 6i will allow me to do some acquisition and how do I combine it with the Vi that I have which saves data. I am sure there is an example I can use to at least acquire some data.
Leye
(3,222 Views)
There are a few examples in LabVIEW 6.i that use 5102 to acquire data. You can find them in the NI Developer Zone, I will attach the link to some of them:
About your VI that saves the data, you can make it a sub vi and configure one of the input to be from the Acquisition vi where the data is acquired. As a side note, NI is releasing LabVIEW 8.0 very soon and will drop the support for LabVIEW 6.i and 6.1. To fully utilize the hardware and its driver software, I  recommend you consider updating your LabVIEW to the current version so you can also use the current versions of hardware driver and all the examples for the scope card.
(3,201 Views)
