Multifunction DAQ
Acquiring Camera and Signal Data simultaneously
I've a problem with acquiring camera and signal data simultaneously.
My system:
- 2 IEEE 1394 Cameras
- 1 PCI 6220 Board
- Windows XP with LabVIEW 8.5, Vision Acquisition 8.5
The cameras and the DAQ board is running correctly under MAX.
I want to display the camera pictures and the signal (12 channels used) simultaneously. No triggering is needed. Unfortunately when I do it like it is shown on the attachment the signal acquisition becomes slow and the acquired data doesn't display correctly (it seems that there is a lag of around 10-20 seconds). When I acquire signals or camera images alone everything works well.
Thanks in advance for your help
Greets
Kane
Message Edited by NKane on 10-26-2007 09:31 AM
(3,156 Views)
Hi!
I would try to put both AI and Image reading in two different while loops and in every loop I would put a timing (f.e. 100ms)
So it will be processed on parallel and no task has to wait for the other before working again.
Best regards
Ken
(3,136 Views)
