Multifunction DAQ
Acquired Samples
Hello
In the VI attached , I want to write the current data acquired from a lamp into a measurement file. Currently when I run the code only 3 values are written eventhough the samples to read and rate is set as '1k'.
My aim is to keep acquiring and writing the current data into the file untill the elapsed time runs out.
(3,984 Views)
No need to double post your question. Here are all the answers that should solve your problem.
CLAMaxime -- Kudos are a great way to say thank you
(3,981 Views)
