Multifunction DAQ
Accessing the Sample Clock
I wish to use the sample clock of my E-Series board to establish a time base (which will have greater resolution than LabViews standard millisecond timers).
How can I do this?
Also, do I have to be acquiring data in order to use the clock? Or, can I still access the clock to use as a counter even when I'm not taking data?
BC
(2,874 Views)
You can use the "timed loop" functionality in LabVIEW 7.1 to use your E-series card's timing to control your software.
Check out this example:
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=EDFBFDB844C96972E0340003BA7CCD71&p_node=%20201207&p_rank=&p_source=External&p_submitted=N
You basically set up a while loop that uses a DAQmx Task to perform timing.
-Sal
(2,860 Views)
