Multifunction DAQ
About input range
I'm using a 6008.
According the documentation, when use input in differential mode,
the input range voltage can be one of the following:
Vmin Vmax
-1 1
-1.25 1.25
-2 2
-2.5 2.5
-4 4
-5 5
-10 10
-20 20
If I would use a Vmin/Vmax different (i.e. 0-5V) in NI-DAQmx
from this "preset" what happens?
The PGA set an amplification to the bring this range
to the nearest preset?
Thanks in advance
(3,145 Views)
If you enter high and low limit as  0-5 V, ADC will set itself to the range closest to it.
In this case -5 to 5 V will be the selected ADC range
(3,139 Views)
(3,139 Views)
