Multifunction DAQ
About DAQ low level drivers documentation and sources
I am using NI USB-6211 DAQ device. I heard that low level drivers are available free ware for Linux. Can some expert recommend where can I find the sources and documentation for APIs? Also, Are there any libraries available for that? I want to do start and stop measurements from my application. Can somebody recommend that which libraries, drivers or documentation should I use? I am only on Linux platforms.
Regards
R.Verma
(3,577 Views)
The DAQmx Base driver is free and available for Linux. Otherwise, you are probably looking for Comedi.
(3,573 Views)
My linux distribution is Ubuntu. Will these work also on ubuntu?
R.verma
(3,563 Views)
My Linux distribution is Ubuntu 10.04. I am getting still problems.
(3,558 Views)
I will club my questions now:
1) I am using Ubuntu version 10.04. I took the .iso image and mounted it. I am using Ubuntu 64 bit version. It seems rpm is supports 32 bit. When I ran
alien -d --scripts *.rpm,
I got the following errors:
error: incorrect format: unknown tag
Package build failed. Here's the log:
dh_testdir
dh_testdir
dh_testroot
dh_clean -k -d
dh_clean: Compatibility levels before 5 are deprecated.
dh_installdirs
dh_installdirs: Compatibility levels before 5 are deprecated.
dh_installdocs
dh_installdocs: Compatibility levels before 5 are deprecated.
dh_installchangelogs
dh_installchangelogs: Compatibility levels before 5 are deprecated.
find . -maxdepth 1 -mindepth 1 -not -name debian -print0 | \
        xargs -0 -r -i cp -a {} debian/labview82-rte
dh_compress
dh_compress: Compatibility levels before 5 are deprecated.
dh_makeshlibs
dh_makeshlibs: Compatibility levels before 5 are deprecated.
dh_installdeb
dh_installdeb: Compatibility levels before 5 are deprecated.
dh_shlibdeps
dh_shlibdeps: Compatibility levels before 5 are deprecated.
dpkg-shlibdeps: error: couldn't find library libstdc++.so.5 needed by debian/labview82-rte/usr/local/lib/LabVIEW-8.2/libnitaglv.so (ELF format: 'elf32-i386'; RPATH: '/usr/local/lib/LabVIEW-8.2').
Note: libraries are not searched in other binary packages that do not have any shlibs or symbols file.
To help dpkg-shlibdeps find private libraries, you might need to set LD_LIBRARY_PATH.
dh_shlibdeps: dpkg-shlibdeps -Tdebian/labview82-rte.substvars debian/labview82-rte/usr/local/lib/LabVIEW-8.2/linux/libOSMesa.so.4.0 debian/labview82-rte/usr/local/lib/LabVIEW-8.2/linux/libstdc++.so.5.0.3 debian/labview82-rte/usr/local/lib/LabVIEW-8.2/liblkrealt.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/liblkdynam.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/nids.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/patchlib/libGL.so.1.2 debian/labview82-rte/usr/local/lib/LabVIEW-8.2/liblvrtdark.so.8.2.1 debian/labview82-rte/usr/local/lib/LabVIEW-8.2/LV82NPlugin.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/liblksock.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/lvdark debian/labview82-rte/usr/local/lib/LabVIEW-8.2/libnitaglv.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/lvanlys.so debian/labview82-rte/usr/local/lib/LabVIEW-8.2/liblvrt.so.8.2.1 debian/labview82-rte/usr/local/lib/LabVIEW-8.2/liblksec.so returned exit code 2
make: [binary-arch] Error 9 (ignored)
dh_gencontrol
dh_gencontrol: Compatibility levels before 5 are deprecated.
dpkg-gencontrol: error: current host architecture 'amd64' does not appear in package's architecture list (i386)
dh_gencontrol: dpkg-gencontrol -ldebian/changelog -Tdebian/labview82-rte.substvars -Pdebian/labview82-rte returned exit code 255
make: *** [binary-arch] Error 9
find: `labview82-rte-8.2.1': No such file or directory
Any views on this...
2) My 2nd question is "does base driver also available for windows freeware?"
(3,554 Views)
