Multifunction DAQ
ASUS Pro Q570M-C doesn't boot after installing PCIe-6730 board
I had to upgrade our lab PC, the system worked fine on a Gigabyte GA-110M-D2P motherboard.
Now I'm using an ASUS Q570M-C motherboard with the same DAQ cards but it doesn't boot if the PCIe-6738 is installed (black screen).
I'm using Windows10 Enterprise with DIADEM , 2x PCIe-6353 and 1x  PCIe-6738
Bios updated on 05/01/2023 but did also only boot without the board.
Is there anyone who had the same trouble ? What is the solution ?
Thank you in advance for all possible answer.
Joao
(1,606 Views)
This issue seems to be one of a kind, I have seen problems with boot-up when you connect PXI systems over MXI to PCs but no issues with PCI or PCIe cards.
Santhosh
Soliton Technologies
(1,580 Views)
Hi Santo_13
It works now !
I had to change the PCIe data rate  in the BIOS to GEN1 , it was set to AUTO .
Thank's anyway for the quick response !
Regards
Joao
(1,545 Views)
Glad you solved the problem, please mark your post as the answer/solution so others with the same problem can quickly navigate to the solution.
Santhosh
(1,531 Views)
