Multifunction DAQ
AI with trigger
Hello all!
I would like to make an acquisition after a cyclic digital trigger.
I solved the problem putting the Start and Stop task inside the loop, but is this an efficient way to do it? Is there a better configuration?
In attach you can see the example.
Thanks in advance, best regards
Paulo Carmo
(2,974 Views)
Thanks for posting on NI forum.
You have a good example of an AI with trigger in LabVIEW. You can find it in Help >> NI example finder >> Hardware Input and Output >> Daqmx >> Analog Measurements >> Voltage >> Acq&Graph Voltage Int Clk-Retriggerable.vi .
This example has the Start Task outside the loop.
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
(2,962 Views)
