Multifunction DAQ
AC measurements using NI-9242
Hi all,
I have an NI9242 voltage input module, wired as per the below diagram:
When I go to NIMAX and perform some measurements in the Test Panels, I get the following readings (the final reading jumps randomly to anywhere on the waveform):
I get same results when measuring it in my VI:
What additional step would I need to perform to get values in ranges of 230V AC? (Same as a handheld DMM would show)
(449 Views)
I made the following changes, now I am getting a proper AC reading:
(436 Views)
