Multifunction DAQ
A simple question about DAQ data sampling
Hi all:
Now I meet a very basic question about DAQ sampling.  I am using NI PCI-6040E DAQ card, SCXI-1001 chasis, SCXI-1102, SCXI1300 terminal block, and SCXI1160 relay module.
I am not sure , is it possible if I want to test a voltage (1 volt) on a resistor. Now I am connecting the Ch0+ to resistor+ (24 volt), and connecting Ch0- to resistor-(23 volt). So the voltage between resistor+ and resistor- should be 1volt.  Actually, It is working at the first, but after I want to test 9 channels based on this connection. The Measurement & Automation can't read data from the DAQ card. (when I test it by multimeter, I can get the voltage data on the Ch0+ and Ch0- of SCXI1300 terminal block).
That's strange, does anybody know what' s wrong about it?/
Thanks a lot
(2,908 Views)
Besides, when I used battery to test it, it is working, MAX can read data from the terminal block.
That's too weird , is there any limit about CH+ and CH- (for example:  I connect a DC 25 volt signal to CH+ and then connect a DC23 volt to CH-)
(2,906 Views)
