Multifunction DAQ
Hi everyone.
I am new to LabView, but not a stranger to NI hardware.  I have a NI9237 Bridge module running in a cDAQ 9172 chassis.  I have downloaded the Bridge - Continuous Input.vi (attached), and found that it does exactly what I need, on a per channel basis, but I need to expand it across all 4 imput channels of the 9237.  I'd likekeep the ability  to enable the Offset Null and Shunt Calibration on a per channel basis. Since I will be only using full bridhe load cells, I can eliminate the case structures for Pressure and Torque from the example, and I've figured that part out, but I don't quite understand what I need to do to sample all 4 channels concurrently.
Thanks for any help!
(5,173 Views)
Hi Zwartpete,
It looks like channel expansion is what you need to accomplish this. Take a look at these two articles:
http://www.ni.com/white-paper/52634/en/
http://digital.ni.com/public.nsf/allkb/B7E7C6A92467E5438625792E0067ED80
Hope this helps!
(5,085 Views)
Since you are using the same device/module, I don't see where any expansion is required. Have you simply tried to select multiple channels with the browse option or just typing them in? The syntax is just dev1/ai0:3 for contiguous channels.
(5,080 Views)
ChaisePotatoe,
Thanks for the info.  It's not quite applicable in my case, as I'm not expanding across different modules or chassis.  I only need to expand the channels on 1 NI9237, but retain the Offset Nulling and Shunt Calibration on a per channel basis.  I think I've found a solution, in that those 2 functions can accept a channel name, and it appears to be working.  Need to do some further testing with different load cells.
Thank You.
zwartpete
(5,070 Views)
Dennis,
Thanks for the help.  My problem is better explained in my reply to ChaisePotatoe - I need to retain seperate controls for each channel, as well as being able to do the Offset Nulling and Shunt Calibration on a per channel basis, so they each need to be individual tasks.  I was having a problem linking those functions to a specific channel, but think I'm on the right track now.
zwartpete
(5,068 Views)
