Multifunction DAQ
9205 trigger
why my signal moves happens over time when it is a trigger (hardware use ni9172 ni9205)
Message 1 of 9
(5,134 Views)
Can you give us more details about your problem (soft version, what are you doing, ...)?
    Benjamin R.
Senior LabVIEW Developer @Neosoft
Message 2 of 9
(5,106 Views)
I use the version 8.5de LV
my problem is that the declenchement does only once at the launch of the stain. in fact I wish he starts at each loop (while)
I find a solution (VI attachment), but I find it too slow
Message 3 of 9
(5,095 Views)
Hi julien03,
When you commit a task that uses analog triggers on the NI 9205, NI-DAQmx delays to allow the NI 9205's trigger circuitry to settle. To speed up your second VI by moving this delay outside the loop, you can use DAQmx Control Task.vi to commit the task outside the loop. One of the examples that ships with NI-DAQmx demonstrates this: Acq&Graph Voltage-Int Clk-HW Trig Restarts.vi.
Brad
Brad Keryan
NI R&D
Message 4 of 9
(5,089 Views)
You also have an example here to know how to use Control Task VI.
    Benjamin R.
Message 5 of 9
(5,080 Views)
Hi.
my problem is not the frequency of sampling but time loop while, too slow. I lost precision.
Message 6 of 9
(5,071 Views)
To increase your time loop put out of your While Loop the Start and Stop Task VIs. Then your time loop will your Sample Clock Rate dependent.
    Benjamin R.
Message 7 of 9
(5,060 Views)
it would be possible to have an example
Message 8 of 9
(5,055 Views)
Here you have a picture about what I described above.
Message Edité par BenjaminR le 05-20-2008 10:56 AM
    Benjamin R.
Message 9 of 9
(5,046 Views)
