Multifunction DAQ
Hello everybody,
I am using DAQmx 8.5 and I simulated PCI 6537 card in MAX. I created a task with one digital input line say Dev1/port0/line0. I configured the task for N sample acquisition. Sample rate is 1K and # of samples to read is 100. When I ran the task, it didn't stop at all!!! I had to abort the task. But the data was acquired and the data got plotted in the graph. Obviously, the same thing happens from LabVIEW also.
Do anybody know why this happens???
Saranya
Note : All the other tasks (with other devices) are running properly.
(3,597 Views)
Hi Saranya,
Thank you for posting this information.  I have duplicated the issue you are seeing, and this was reported to R&D under CAR ID 48BE27TC for further investigation.  I hope this does not impede the testing of your application.  The tasks should run properly on non-simulated devices... please try this as a workaround.  Thank you for the feedback!
Nicholas B
(3,586 Views)
Hi Nicholas,
Thank you for reporting the issue to R&D. Since I do not have that device, I cannot run it in non-simulation mode.
Anyway, thank you again.
Saranya
(3,579 Views)
Saranya,
You could develop your code by simulating a PCI-6534, the functionality should be similar enough to get your development started.
Good luck with your project.
Juan Carlos
Message Edited by JuanCarlos on 04-13-2007 09:38 AM
(3,573 Views)
