Multifunction DAQ
6341-USB setup query.
Hi everybody. I'm not new here, but it's been a long time and I forgot the email addy I signed up with.
Anyhow...
My company has a device which produces pulses from 2 separate sensors (A & B) which are physically locked together on a rotating shaft. The measurement needed is the phase difference between them. If these inputs are armed from the leading edge of A and XOR'd together, the mark space ratio of the result directly relates to the phase difference, whatever the shaft speed. This, I believe from the manual, requires an 'implicit buffered pulse measurement, which returns both the mark and the space counts as a unit. The problem I'm having is working out whether any of the vast array of input routings to the board will result in the XOR function, or will I need to implement this initial input in hardware? Perhaps there is a quadrature method of addressing the problem? Ideas appreciated.
Rgds - Steve.
(3,976 Views)
Honestly I would just use an external hardware XOR and wire the result into the DAQ card for the cleanest solution.
Two other options I can think of though...
1.  Combine a two edge separation measurement (to get absolute time difference between pulses) with a frequency or period measurement on a separate counter.
2.  Assuming the inputs are both the same value to start out, if you toggle the state of a digital output every time one of the input signals changes state, you effectively have your XOR signal.  A digital input task with change detection timing can be used to generate a clock (called the "change detection event") on each state change of your A or B signal.  Use this change detection event as the sample clock for a digital output task which runs continuously with a buffer of alternating 1s and 0s.
Best Regards,
John Passiak
(3,955 Views)
Thanks for the time and consideration. After more thought it seems that hardware is definitely the way to go, although the labyrinthine dig-in routing does have definite merit in the 'blind the boss with science' stakes. A part I didn't mention was that the initial input is a smallish sine wave which will need  squaring. The trigger point of the comparators is critical to accuracy and will have to be determined by calibration. Happily I have 2 very accurate analog outputs for this very purpose. I love it when a plan comes together.
(3,947 Views)
