Multifunction DAQ
6110 HW error code 10 HW does not start, used Legacy NI 6.9.3
With older MB Intel945GNT we had no problems. With MB based on P35 chipset we received above mentioned error - HW simply does not start. What could be root cause? Now we trying Legacy NI 7.4.4. Could this board depend on PCI clock/maste mode/etc? thanks.
(3,008 Views)
Hello Fei,
thank you for your post on our webforum. I couldn't find a reason why this card doesn't run on your system. Which operating system are you using?
Are you using the testpanel in the Measurement and Automation explorer (to discover error code 10). I discovered some problems with NI DAQ 6.9.3 and NI DAQ 7 on some pc hardware that causes this problem. The new driver should resolve this issue, please let me know if this new driver doesn't work.
Martijn S
NI Netherlands
(3,001 Views)
