03-30-2007 08:26 AM
04-02-2007 10:43 AM
04-02-2007 09:12 PM
Thanks for the info. I guess I should read the manual more in-depth. I was able to get the sampling working the way I wanted too. If I set up the channel with the following config I can then, after starting the task, read 1 sample for each iteration of a WHILE loop and it is harwdare timed.
On another note, can I set up digital I/O on the same task that I use for the analog channels? I tried it but I get errors so I think not. I suppose I will have a separate task for analog input, digital input, and digital output. Each task is setup in it's own VI, similar to what you get when you generate code from the Express VI.
04-03-2007 09:04 AM
