Multifunction DAQ
2400 Source meter output not good
Hello everybody,
I have a problem with the Source meter.
I think the output of the 2400 Source meter have a problem.
I used the Oscilloscope to check the output of the 2400 Source meter. I saw the waveform, the waveform has noise.
Why it has noise.
How can I set up so that the waveform hasn't noise.
Thank you very much.
Best regards
Van Phu
(3,797 Views)
You will always have noise 🙂
You didn't tell numbers ....
What does the spec tell you?
How is your setup?
Finally:  Any kind of picture or samples data would be helpful 😉
Greetings from Germany
Henrik
LV since v3.1
(3,793 Views)
There is no 2400 soruce meter from NI. Are you talking about the one from Keithley? If so, you posted to the wrong board as that is not an NI multifunction DAQ device. I also agree with Henrik that you have not provided enough information.
(3,789 Views)
