Multifunction DAQ
2 while loops
I am using one while loop to acquire current  from a motor controller . I am using a second while loop to move the motor by sending commands to it.
I want to use the current data in the first loop and send it to the second loop for processing .
How do i send this data to the second while loop ?
(2,976 Views)
Thanks for the post and I hope your well today.
You have two options:
1) Use variables - this method is good for control signals (such as stop etc) but not great for avoiding loss of data.
2) Using queues you can store data in a buffer, and then 'get' the data back as and when you want it in the 2nd loop. For more info on queues, please look in the LabVIEW example finder, Help>>Find Examples>> Search 'queues' and take a look at Queue Basics.vi.
I hope this helps to get you started!
Kind Regards,
James.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,975 Views)
