Multifunction DAQ
1ms Counter Loop / Event trigger from counters
Sorry, This message was intended for the LabView Forum!
Hi.  I'm pretty new to LabView so I'm am hoping this is an easy question:
I need to read the pulse signal from some reluctors (toothed wheels that pulse a signal with each passing tooth).  The amplitude of each pulse is above 2.2V so I was planning on using TTL counters.
I need to record the status of 5 counters with each increment of one of the counters  For the RPM and tooth count, I can do this with a 1ms timed loop.
Question:  Can windows successfully give a 1ms (accurate) timed loop?  I know this depends on how much I am doing inside the loop but, for now, I just need to read 5 counters and store the data with a timestamp.
Is it possible to make a counter throw an event?  If the counter is incrememented, can LabView be notified to then go off and handle a block of code?
Thanks for any help you can offer!
(2,945 Views)
Seascan,
Windows does seem to give a fairly accurate 1ms but extremely dependent on whats going on in the OS. Something as common as a windows update can skew this timing.
LabVIEW does have a wait until next ms multiple vi to time your loop efficiently.
Some counters do support DAQ events that LabVIEW can recognize but it is dependent on the device.
Daniel
(2,918 Views)
