06-11-2014 10:35 AM
HI,
I have an labview application using continuous measurement of sensors which writes to a remote server via internet. Lately I am getting this error 0x80004005 and the recording stops which then needs manual restart when we login to check if everything is working fine or not. The frequency is high and I dont think its becaouse of the network. Can some one help with the trouble shooting
06-12-2014
05:14 PM
- last edited on
02-24-2026
10:06 AM
by
Content Cleaner
Hi rajcerc,
Which protocol are you using to connect to your server? Are you using a database or database tools in your VI? Is it working for a specific amount of time before you get this error or is this happening on the first "iteration" of your code?
I found these two KnowledgeBase articles related to the error number you are getting - if they are not relevant, having more information regarding your overall VI's architecture, communication protocol as well as OS/LabVIEW versions would help.
1. What Does Error -2147467259 Mean When Connecting to an Oracle Database?
2. Error -2147467259 from Database VI on Windows 7 64-bit
Hope this helps!
