Motion Control and Motor Drives
turn to active mode
i tried to connect labview with wolidworks
but when i tried to convert to active mode i got this problem in the error
can any one help me ?
thanks
error
https://www.dropbox.com/s/89xxj1yc79h62l2/ddd.png
(5,971 Views)
https://www.dropbox.com/s/mx1tm368n761a7b/error.png
and this one not active also
(5,965 Views)
Accepted by topic author Eng.Tareq
Please try the followings steps to clear that error:
  1. Delete the contents of the following folder: C:\ProgramData\National Instruments\DeploymentFramework. Note that the ProgramData folder is hidden, so you may not see it if your folder options are set to not show hidden folders.
  2. Close LabVIEW and repopen.
This should allow you to deploy and use your SolidWorks axes.
(5,961 Views)
