Motion Control and Motor Drives
to drive a brussless DC motor by NI PXI -1042Q ,NI-DAQmx8.x,Danaher Motion kollmorgen using Labview real-time Module
I have a question regarding a system set up  to control a brushless servo DC motor by the National Instruments PXI-1042Q controller ,the NI-DAQmx8.x , Danaher motion kollmorgen using labview real-time.  when running labview real-time program ,I wrote data (from 0.1 to 0.6 )to DAQ, The motor did not move .By checking ,kollmorgen is the problem.How to tune it
Thanks.
(3,896 Views)
Hello jianying,
If your RealTime PXI system is networked to your development machine, you can use the Measurement and Automation Explorer (MAX) on the development machine to remotely “add” the PXI chassis and all cards to your “Devices and Interfaces” Configuration tree. Once you have added your PXI system to MAX on the development machine, you can use the Interactive Control functions to configure your hardware settings.
For information on these settings, see the Help file for Motion in MAX by selecting Help >> Help Topics >> NI-Motion >> NI-Motion Configuration Help, and navigate to Using MAX to work with your NI Motion controller >> Interactive Environment >> 1D Interactive Environment >> 1D Interactive Main.
I hope this is enough information to get you up and running!
David G
Sales Engineer - SE Michigan & N Ohio
(3,882 Views)
