Motion Control and Motor Drives
stepper motor that are NI compatible?
dear all,
we have to try developing a motion control application with a working rate of about 50 positioning/s, for which we were thinking about to deploy stepper motor. After a quick model of the application, I need some fast (>3000 rpm), low inertia motors.
As I am fresh into the motion control topic, can anybody suggest stepper motors that are Labview compatible?
Many thanks,
Kind regards,
Edo777
(3,537 Views)
Hi Edo777
The more I can do is to suggest you to verify which are your system's requirements and than to search a solution from the NI Stepper Motion System Selection Guide.
Hope this will help you!
If you need a more accurate support on your choice i will recommend you to contact NI directly.
HUDSON
(3,500 Views)
