Motion Control and Motor Drives
sample solidworks assemblies available anywhere?
Hi folks, I am working on a research project looking at controlling simulated equipment from a C# application, using SoftMotion for SolidWorks to interface with an equipment assembly in SOlidWorks. The focus is on the C# and LabVIEW parts of this, the equipment could be anything. The problem is I am a coder rather than a designer - I'll eat up the C# and LabVIEW but building a suitable assembly in SolidWorks could take me weeks. Does anyone know if there are suitable sample assemblies available anywhere? There is a nice single axis assembly used in a tutorial at http://zone.ni.com/wv/app/doc/p/id/wv-1417 which would be perfect. I just need something with a motor and one axis. Thanks Fran
(6,195 Views)
Dear Wolfbag
What you've found is a good start.What I also recommend is looking in the NI Example Finder, searching for the keyword "solidworks". In here are 5 good examples to help you get started including a linear and rotary motor in a Solidworks Assembly. Unfortunetly with regard to Solidworks assemblies, there are very limited examples I have, unless the community here have some of their own.
Also, there is another good reference guide which I've referenced below:
Getting Started with NI SoftMotion for SolidWorks
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
(6,180 Views)
David, Thanks for the tip, there's one there (http://zone.ni.com/devzone/cda/epd/p/id/3402) which has a SolidWorks assembly attached which I'll have a look at. Even if its not suitable for what I want to do there will be some learning in it. Cheers Fran
(6,168 Views)
Hi ,can you give me a chance of being becoming your frident,I am a student in china ,persuning a master degree in Zhejiang Sci-Tech University Zhejiang Province in China, my research area is parallel robotics.Now i am studying the labview softmotion for solidworks ,if you give me you MSN or MSN that is talking about or communicating the Labview softmotin for solidworks with other ,any reply will be apperciated ,looking forward your reply ,my chinese name is hanayng ,my address is the College of Mechanical Engineering and A utomation in Zhejiang Sci-Tech University 5 Second Avenue,Xiasha Higher Education Zone ,Hangzhou,China,310018,my email is hanyang19861017@163.com
(5,911 Views)
Hi, I found the links below gave me everything I needed to know to get started...I hope they help. If you want to see the SolidWorks and LabVIEW components I used I have posted them at http://sites.google.com/site/franmccmscsis/documents-assignments. The SolidWorks model is very simple as it was only used as proof-of-concept. The LabVIEW VI includes TCP/IP communication with a C# application. http://www.ni.com/virtualprototyping/training.htm  https://www.ni.com/docs/en-US/bundle/372876e/resource/372876e.pdf https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHUpCAO&l=en-US
(5,885 Views)
