Motion Control and Motor Drives
"Distributed motion control'
Hi there,
For a future project we are making a first study, and as I'm not really familiar with NI solutions, I hope some of you can share some thoughts.
For this project, we will have to control the following hardware:
 - 28 cryogenic stepper motors in open loop (no encoder feedback possible) and very simple motions ("move x degrees") just a few times per hour max.
 - 2 cryogenic stepper motors in open loop, but with a constantly changing position setpoint (>50Hz should be fine)
 - 50-100 I/O temperature and pressure readings (sampling in de range of a few Hz maximum)
How would a possible "NI solution" look?
Our systems engineering guidelines say that it is highly preferrably to move the "control unit" away from the instrument (say 50 meters apart, in a computer room), and that all fieldbuses should be ethernet based. In that case I was thinking to have:
 - a PXI chassis in the computer room
 - an EtherCAT connection from the PXI chassis to a daisy chain of 4 NI-9144 expansion chassis, all equipped with the 28+2 NI 9512 stepper controllers, connected to 28+2 stepper drivers
 - an extra NI-9144 (or compactFieldpoint chassis) for the DAQ
It seems quite rediculous to have so many NI-9144 expansion chassis, so another solution is to ignore the "control unit near instrument" rule and to have a single PXI controller with 4 8-axis stepper controller boards and a few DAQ boards inside.
Another solution would be to have 28+2 standalone third-party stepper "controller and drivers" inside the instrument, connected with an ethernet fieldbus to a labview target in the computer room. But I'm having troubles of finding suitable stepper controllers+drivers (maybe because stepper motors and ethernet motion control are not so commonly found in industry?)
Thanks for any thoughts on this,
Wim
(4,054 Views)
I'm very curious how you solved this.  Can you provide any details?
Thanks!
Steve
(3,250 Views)
We've roughly worked out a layout of such a control system on paper, but it remains a quite vague "study" until the project enters the next stage (which depends on funding since it's a scientific instrument). I can send you a document about it if you want (just PM me your e-mail address), but I doubt it'll be of much use. Anyway the final solution will look much different from our original plan, and if I'd have any say in it, I'd most likely choose a PLC-based solution over this one.
Wim
(3,247 Views)
