Motion Control and Motor Drives
on board program
Using Labview 7.1, PCI 7342, what are the advantage and disadvantage of using on board program and program in host computer? If using on board program, is the motion controller a stand alone or PCI/PXI type?
Thanks.
(3,576 Views)
The following tutorial link discusses advantages/disadvantages of using on-board programming with the PCI 7342.
On-Board Programming in FlexMotion
I hope this helps!
Doug K.
Application Engineering
(3,576 Views)
Can onboard program is programmed with Labview? Seems all onboard program is in C, VB or CVI.
Thanks.
(3,576 Views)
Yes you can use LabVIEW to do on-board programming. The tutorial in my post above has links for VI's in LabVIEW that demonstrate how to perform Do-While loops, For loops, and other functionality. I've included a document with this post that goes into more detail of on-board programming with LabVIEW.
Doug K.
(3,576 Views)
