Motion Control and Motor Drives
measurement automation explorer
I am currently trying to modify the acceleration in NI-MAX and in either way, if I change it in 1D Interractive or in trajectory settings it is impossible to change the value below 4000 step/s^2.
So my question is how may I change this value to one below 4000 step/s^2 in NI-MAX?
Thank you very much.
(5,870 Views)
You can't go below 4000 in MAX, programmatically you have to use the Enable Axes.flx function to change the controller time base. Refer to NI 73xx Time Base section (and to the following sections of chapter 4) of the NI-Motion User Manual for more details.
Ben64
(5,855 Views)
