Motion Control and Motor Drives
how to created a virtual axis with an encoder on NI9411 slot
  Dear,
I would like 'gearing' a motor (Axis 1) with an encoder (Axis 2 -> just an encoder not motor).
In order to used the gearing function of the softmotion, I need to created an Axis on my project.
Is it possible to created an axis, when  my encoder in connected on a NI 9411 slot? Unbound Axis?
If it's impossible, how gearing a motor (Axis 1) with just an encoder (Axis 2).
  Regards
  Massif
(4,949 Views)
Hello Massif
Your understanding is correct, you will need to have two axes in order to gear them. To setup the 9411 as an encoder you will need to create an Axis Interface VI and use gearing. I recommend getting started with the 9401 encoder example. I have attached it below since in 2010 the example was removed (CAR . 258565). You will need to open the FPGA block diagram and modify the digital I/O to read from 9411 lines instead of the 9401. This should be a fairly short process. After this has been completed you can run the 951x module and the unbound axes 9411 together using the cRIO in hybrid mode, see the article here for more details.
Thank You
Eric Reid
Motion R&D
(4,916 Views)
   Dear Eric_R,
Thank you for your respons.
I will try this without used the capture and compare functions.
I just need the axis position en vélocity.
I will let you know, if it's working.
   Massif
(4,845 Views)
Yes, it's working!
(4,834 Views)
