08-21-2010 06:07 PM
Hi, I am a new Labview user. I am trying to write a simple code in Labview 8.6 to control a stepper motor and do some profiling with a probe which is being moved by the motor. So far I have been able to control the motor but I cannot get the motion data while to motor is moving. For instance I need to know how many steps the motor has moved at a desired frequency while the probe is giving data at the same frequency. Can anybody help me please?
To make it clear I wanna plot the probe data as a function of position. So I need to know how many steps the motor has moved at each time also what value the probe is giving me at that particular time.
Thanks a lot
08-26-2010 03:55 PM
Payz,
What hardware are you using? Do you have an encoder connected to get feedback from you stepper motor? As well which motor are you using?
The documents below should help:
Fundamentals of Motion Control - Developer Zone
http://zone.ni.com/devzone/cda/tut/p/id/3367
Axis Configuration for Motion Controllers - Developer Zone
http://zone.ni.com/devzone/cda/tut/p/id/3899
Configuring a Motion Control System - Developer Zone
http://zone.ni.com/devzone/cda/tut/p/id/3126
Best,
Chris LS
