Greetings,
We are trying to use a PCI-7354 for hydraulic servovalve control. The output, the command signal and feedback signals all need to be analog voltage signals. We would like to generate the command signals via a DAC card or other external device. The PCI-7354 axis voltage output is then directed to a current driver which interfaces to a Moog style servovalve. It would be preferred to generate a user interface using Measurement Studio, or making use of the NIDAQ function library, however if we can just setup the controller in MAX that would be fine as well. In this application there are no encoders.
I haven't been able to find the scenario in this forum, where both of the analog inputs are used for Feedback and Command respectively. That is, we input to Axis 1 the Feedback signal on Analog Input 1 and the Command signal on Analog Input 5 and the DAC output is generated as determined by the gain settings for the PID parameters. This configuration would then be repeated for Axis 2, 3, 4 etc.
Please let me know if this is possible, even if it would require a custom firmware modification.
Thank you,
Johannes
