Motion Control and Motor Drives
absolute position won'[t work
Sean,
Which example VIs were you using when testing your hardware?
Larry H.
Message 21 of 24
(3,126 Views)
I used the 'simple one axis move' VI.
Sean
Message 22 of 24
(3,124 Views)
Sean,
Just to update you, we're going to try to reproduce your issue on our end and hopefully pinpoint where the problem is coming from. We will get back in touch with you as soon as we know more.
Larry H.
Message 23 of 24
(3,118 Views)
Accepted by topic author shalloras
Appears that the "Load Velocity Override" VI is the culprit.  When I set it to zero, it holds on to this, preventing other moves to be made.  The simple work around is to set it to 100% before any other type of move or when you close the VI.  Here I exit the WHILE loop and set the override back to 100%.
Absolute position moves work fine now!
Thanks for all your help.
Sean
Message 24 of 24
(3,044 Views)
